Re: FARMALL H CARB ADJUSTMENTS??
Posted by T_Bone on October 14, 2000 at 02:27:42 from (207.254.53.37):
In Reply to: FARMALL H CARB ADJUSTMENTS?? posted by LOU on October 13, 2000 at 18:14:55:
Hi Lou, I've never worked on a H, but lookin at the parts book:
1: On the upper main body on the left side is the idle rpm adjustment. Adjust for proper rpm at idle.
2: On the lower left side body, is the idle inrichment screw. Turn for best idle, but if turn all the way in and it makes no difference then the idle circuit is still plugged. Reclean. A preset is 1 turn out from seat.
3: On the lower body bottom a screw running from right to left at a 45 degree angle is the high rpm fule mixture screw. Run engine at 1500rpm and set for best rpm without missing. A preset is usually 1-1/2 turns out from seat. A Rich setting is better. I usually turn to best lean run, then turn rich 1/4 turn. Lean is screw in, rich is out.
4: On the upper body rigth side next too the fuel inlet there is a idle passage plug. This should be screwed all the way in. But if idle circuit is running ruff, then remove and clean passage with Chemtron Berriman B-12.
5: Inside of lower bowel left side is a idle jet metering screw, so that should be cleaned upon rebuild.
6: On lower right side is a pin, ball,and spring used to set tension on the choke butterfly and used as a dent setup to hold the choke open.
Thats all I can see in the diagram and should be a complete adjustment. Let me know if you need more help!
T_Bone
Post A Followup
: Re: Re: FARMALL H CARB ADJUSTMENTS??
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
