Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: FARMALL H POWER STEERING
Posted by Ralph on January 12, 1999 at 19:05:42:
In Reply to: Re: Re: Re: Re: FARMALL H POWER STEERING posted by MARCO on January 12, 1999 at 04:42:36:
Marco: At least you are getting some response. One thing to consider is how to drive the pump from the crankshaft. Charr-lynn had a kit for at least the "M"s and probably the "H"s as well that had a pully you put on the crankshaft after taking out the pin for the crank, slip on the pulley and put the pin back in. If this is a char-lynn unit make sure the steering unit does not leak. I have too in the shop both leak and won't hold a seal. We have a Behlen unot on one "M". it works slow but good and is big and clumsey and almost has to be mounted over the gas tank. Is this on a wide front? If it is there are some other options that could be used. Good Luck Ralph
Post a Followup
: Re: Re: Re: Re: Re: Re: FARMALL H POWER STEERING
