Re: H-4 Magnetp
Posted by Jim Becker on September 16, 2012 at 19:41:10 from (173.74.120.222):
In Reply to: H-4 Magnetp posted by A.Lambert on September 16, 2012 at 17:09:28:
The rotor drive gears inside the magneto have timing marks. One gear has marks for Right and Left. Use the "R". If they weren't lined up when it was assembled, fix it before going on. If that is OK, you need to install the magneto on the engine using the instructions in your owners manual. The instructions will work if you follow them EXACTLY. Pay attention to every if and but and comma. If it says turn the drive backwards, don't try to turn it forward to the same place. If it says to stop and scratch your butt, stop and scratch your butt. The instructions will work.
