Re: Super M fan belt
Posted by kevinj54 on September 17, 2012 at 04:15:18 from (99.39.189.166):
In Reply to: Super M fan belt posted by Janicholson on September 17, 2012 at 02:14:18:
One other thing......cut the belt off so you can get oil to the back side and you will not have the resistance of the belt either.
When you have it loose put a very SMALL amount of never seize on the threads and work it in prior to installing the belt.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
