Posted by RPM1941 on September 17, 2012 at 06:49:49 from (173.23.76.185):
In Reply to: 1486 cab solenoid posted by Mark Beyers on September 16, 2012 at 17:52:24:
Cab solenoid 107655C1 is the good IH/CNH one. I suspect your cab fan motor is drawing to many amps, in other words needs replacing. It is 1987399C2 usually.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
