Re: Super M fan belt
Posted by The tractor vet on September 17, 2012 at 08:21:32 from (75.24.7.240):
In Reply to: Super M fan belt posted by 47 Bill on September 17, 2012 at 02:14:18:
Well on the first attempt i like to wire brush the threads as clean as i can get them then get the set screw out all the way . Myself i use Zep penetrating oil as i have found tis to be the best but i will use Blaster not as good but ok. I havea half inch. dia. brass drift and lightly tap as yes i have broken one and only one sofar once was enough . Then if that attempt does not give me any results then i heat it but not cherry red maybe 2-300 deress as fast as i can then lightly tap and get it moving just a little and keep working it back and forth .
