Re: Farmall 450 lp slow throttle response
Posted by The tractor vet on September 17, 2012 at 08:48:23 from (75.24.7.240):
In Reply to: Farmall 450 lp slow throttle response posted by Farmall 450 lp on September 16, 2012 at 18:47:07:
well i would take a look at the gov. and see how sloppy the gov. spring fits into the levers-arm inside the Gov.There should be no slop as there should be bushings where the spring goes thru the arms. if they are not there then you can make up either bronze or steel bushings and press them in . IF you make them you must chamfer both sides of the hole where the spring fits thru so it does not bind. Then look and repair fix any sloppy linkage from the throttle lever down to the gov. I think this is your problem .
