Re: Liftall
Posted by LenND on September 17, 2012 at 12:42:58 from (74.207.160.118):
In Reply to: Liftall posted by jbp on September 17, 2012 at 09:00:37:
If you want two way(up and down)pressure do this: Put a hose from right pump outlet to a two-way (single lever) valve inlet. Then run a hose from outlet side of valve to oil filler tube. On the filler tube remove cap, put in a pipe tee. short length of pipe nipple and cap. From the side of tee hook up your return hose from valve. Your set togo for up and down pressure. Oh, I hooked a tarp strap to the pump lever to keep it on. Len
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
