Re: restarting dry engine
Posted by old on September 17, 2012 at 14:37:10 from (209.86.226.34):
In Reply to: Re: restarting dry engine posted by Rod51M on September 17, 2012 at 13:24:23:
ATF or also known as automatic transmission fluid. ATF is a light oil that has a lot of cleaning additives to it and it eats carbon and rust and frees up sticking parts better then most penetrating oils do. There was a study done and ATF came out as one of if not the top penetrating type oils. I keep a pumper oil can full of the stuff and use it a lot. It can also be used in place of MMO and cot a lot less and works as good or better just does not smell as good
