Since it is a tapered pipe plug, drill a small pilot hole in the center ( 1/8 in bit) then enlarge to a 3/8 in, then try using the LARGE square easy out and a wrench that just fits, a crescent wrench isn't the answer here.
Before you put in the easy out, use a 3/8 in chisel and make a cut at the top rh corner then try to tap it couterclock wise to loosen the plug. If the chisel starts to chip out the corner STOP. Tap the plug flat face with a ball peen hammer three times, then the easy out should bring it out in 1 piece.
If after all this the plug refuses to move, it's time for some heat.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
