Re: Grounding the battery
Posted by Jon Hagen on September 17, 2012 at 17:45:54 from (69.26.17.61):
In Reply to: Re: Grounding the battery posted by The Red on September 17, 2012 at 14:56:12:
All those joints (engine to starter nose, nose to field and field to end cap. All to get corroded and make a bad connection.
That is why the newer large Delco starters have the brushes in the end cap and a "ground " stud bolt directly on the end cap. That eliminates all those potential bad connections with both battery leads connected directly to the starter.
