Re: pressure plate adjustment 560 D
Posted by Janicholson on September 17, 2012 at 18:16:56 from (96.24.99.126):
In Reply to: pressure plate adjustment 560 D posted by tn terry t on September 17, 2012 at 17:42:08:
You can, but it is not the issue, and will be hard to get even if tried. The issue mahy be the release fork to shaft connection, wrong throwout bearing, wrong clutch Pressure plate, improper flywheel depth step from repair without proper specifications. Go there before turning the finger screws. A radically worn out pressure plate can also be beyond adjustment if the finger pivots are worn way egg shaped. Jim
