Re: pressure plate adjustment 560 D
Posted by pete 23 on September 17, 2012 at 18:20:23 from (74.32.238.2):
In Reply to: pressure plate adjustment 560 D posted by tn terry t on September 17, 2012 at 17:42:08:
If tractor has original IH clutch you can adjust the
fingers, but the way it sounds you have some other
problem. Have you just installed a new clutch and
disk is too thick or flywheel step was not
resurfaced to proper dimension. If not, sounds like
fingers and bearing are worn out.
