With it not running, push in the clutch all the way. Put it in neutral, and (keeping the clutch down) start it. If it grinds into gear in this test, it is having issues. The pilot bearing may need grease. The clutch disk could be warped. The shaft splines with a new clutch can cause the plate to drag. The driven disk could be coming apart. Easiest first. If the test doesn't grind. check trans fluid level. and or refill with 85-140 gear oil. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
