Re: How do I jack up my M?
Posted by Andy Martin on October 14, 2000 at 13:35:13 from (38.31.75.47):
In Reply to: How do I jack up my M? posted by Lowell Davis on October 14, 2000 at 09:28:15:
I regularly jack M's up on the drawbar angle when all I have is a floor jack, and the tractor is on a firm and level surface. The drawbar should hold the tractor unless it is loose, cracked, or broken.
I'll repeat the warning to not remove the rim or wheel because the jack is close to the centerline of the tractor and movement could cause it to shift positions. You can block it up if you want to take something off.
Post A Followup
: Re: Re: How do I jack up my M?
