Re: Used Tires 12.4 x 38
Posted by mkirsch on September 18, 2012 at 06:46:33 from (64.80.110.75):
In Reply to: Used Tires 12.4 x 38 posted by j hakenwerth on September 18, 2012 at 06:28:37:
Hard as in the opposite of soft. As rusty said, the rubber has hardened making the tire very stiff.
Hard is a BAD thing when you're trying to get the tires on/off the rims. The rubber can crack while you're flexing the tire, trying to pry it on to the rim.
Depends on how hard is hard, whether they're worth buying or not. Different people have different ideas of hard. The tire could be a little stiff, or as brittle as glass.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
