Re: pressure plate adjustment 560 D
Posted by tn terry t on September 18, 2012 at 06:59:29 from (75.246.143.168):
In Reply to: pressure plate adjustment 560 D posted by John G. Hasler on September 17, 2012 at 17:42:08:
Quoting Removed, click Modern View to seegene i have plenty adjustment on the rod between pedal and the clutch release shaft assembly but the clutch release shaft assembly lever hits on the bellhousing and stops it from going any further foward that why i was wondering if i could adjust the fingers out twards the throw out bearing thanks for all the replys! i need to crawl under and look closer. it has adjustment on the pressure plate but will take you guys advice and see if i can find anything else wrong
