Posted by Super-H-Mike on September 18, 2012 at 11:14:59 from (76.164.146.124):
In Reply to: Re: Anti-Sieze posted by FBH44 on September 18, 2012 at 09:57:40:
The metal is always clean, either by sandblasting or grinding. I do suspect that the anti-sieze may actually be making it worse , is that possible? We are talking about massive amounts of ice melter put on the roads here that creates a semi-liquid type of brine if you will, that coats and penetrates almost everything .
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
