Clean all mounting points to shiny bright metal, apply di-electric grease prior to re-assembly. These points are essentially your ground for the lights, clean contact between the brackets, post & chassis.
1. Remove the bolts that hold the light bar to the top of the tranny, sand both to shiny metal, apply the di-electric grease & re-install.
2. remove the ubolts that hold the light bar to the post, and sand where they contact to bright shiny metal, apply the same grease & re-tighten.
3. remove the clamps that hold the lights around the light bar at the bottom & sand to bright shiny metal, apply the grease & re-install.
4. Take the cover off the ammeter box, removing the light switch wires one at a time, sand the terminal & wire connector to bright shiny metal, apply the grease and re-install.
On a 6 volt system all corroded connections reduce amperage & cause dim lights & dead batteries.
Bet you have some bright lights now !!!
Remove the excess grease at the connecting points, on the light bar, post & clamps, clean with brake clean, prime & re-paint only the exposed areas.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
