Re: Lighting problems on M
Posted by gene bender on September 19, 2012 at 02:49:53 from (67.55.226.162):
In Reply to: Lighting problems on M posted by Rod51M on September 18, 2012 at 18:57:18:
Not all lites had that tab but if you clean everything so you get a good ground they will work. The lite bar mite not even have a good connection to ground. Cant beat an OHM meter for these problems also do you have battery volts at the connections.
