Re: Super A start problem
Posted by gene bender on September 19, 2012 at 03:00:25 from (67.55.226.162):
In Reply to: Super A start problem posted by freefour on September 18, 2012 at 17:26:48:
Just nobolt the starter ive never had much luck rocking the tractor i just take the mounting bolts out. Now for a permantnt fix get the starter refreshed new bruches,bearings and drive. When the starter is removed check the ring gear for bad spot mite need to split and replace the ring gear. If it isnt totaly ruined you can just reverse the ring gear. Bad connections and weak starters contribute to the ring gears getting ground off.
