Re: Lighting problems on M
Posted by FBH44 on September 19, 2012 at 03:01:35 from (64.85.221.108):
In Reply to: Lighting problems on M posted by Rod51M on September 18, 2012 at 18:57:18:
I never could get a good ground through all those rusty connectins of light bag, u-bolt, tractor frame, etc. so I ran a separaet green ground wire. I screwed a small hose clamp to the light socketitself, inside the fixture, then ran the wire from there out through s small hole I drilled in the housing, then down to the battery ground terminal. Works great.
