The camshaft gear has portions of the teeth missing in the center portion of parts of the gear. The outer edges are okay, which is probably why it is still spinning and still works the pump. There is one part of it where the edge is missing pieces of 2 teeth.
I have several different types of pullers and have a torch for heat.
I"ll support it under the bell housing. Didn"t think about a block under the drawbar. Hopefully, I do not need to pull the engine though.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
