Yes, you need six bolts to mount two sets of weights as originally designed.
Four 3/4" bolts hold the first weight on through the center holes. The second weight is held on with two 5/8" bolts through the slots in the outer slots/holes.
This is so you don't have to juggle 300lbs of cast iron while installing the four center bolts. If you're young and strong and bullheaded, you can do it.
Another way to go about it is to use all-thread (threaded rod). You can cut long studs long enough to hold as many weights as you want to install, and bolt them to the wheel centers, nuts on both sides to hold them firm. Then simply slide the weights on to the studs.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
