Re: F-30 engine
Posted by F-Dean on September 19, 2012 at 06:30:59 from (70.194.70.49):
In Reply to: F-30 engine posted by Fritz Maurer on September 19, 2012 at 06:14:40:
Yes. This means that the rods and pistons are interchangeable.
The main difference is the water pump. The F-30/W-30 block and head has a different water flow and different "holes" between the head and block which requires a different head gasket.
My early W-30 has a 10-20 block which means it uses a 10-20 head gasket.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
