Re: Right/Wrong to mount rear wheel weights
Posted by sflem849 on September 19, 2012 at 06:51:26 from (69.197.84.39):
In Reply to: Right/Wrong to mount rear wheel weights posted by Craig Tenhoff on September 18, 2012 at 17:27:16:
third party image
One thing you eliminate by putting them on correctly is the possibility of smashing your fingers. There are built in hand holds on the weights and these solve that problem. Technically there are 8 different ways to mount them (forwards and backwards and clocked in 4 positions each) but only one right way. That would be with all hand holds aligned and upright. Then again when the tire spins they will be upside down, but your first set better match you second!
Nobody brought it up, but the "oval" in the middle should be oriented with the hub adjusting bolts. This will allow adjusting of width with the weights on.
