Re: Lighting problems on M
Posted by The Red on September 19, 2012 at 13:51:42 from (69.246.205.0):
In Reply to: Lighting problems on M posted by Rod51M on September 18, 2012 at 18:57:18:
I went through this problem when I did a "Dupont restoration" on a 1946H back in the early 1990s. I ended up pulling up the steering post to wire brush clean the bottom of it and where it bolted to the flooring. Then took off the light assembly bar and wire brushed it cleaned where it mated to the steering wheel post. Then cleaned up where the light clamps bolted to the light bar. That did the trick!
