Re: farmall a problem
Posted by old on September 19, 2012 at 13:52:28 from (209.86.226.32):
In Reply to: farmall a problem posted by michael solan on September 19, 2012 at 13:26:36:
Sounds like you have some rust/dirt in the carb and it blocks the main jet at times then falls away again and unblocks it. But I would first test spark and make sure you have a good blue/white spark that jumps a 1/4 inch gap or more. Then I would pull the carb drain plug and let the fuel flow a couple minutes. Catch it so as to look for rust/dirt and water. If your carb is like the one on my BA it had the non-adjustable main jet with a plug covering it. Remove that plug and let fuel flow out of the man jet. If it does not flow out well then take a small wire etc and poke in it to open it up. Also when was the last time you dumped the dirt and water out of the air cleaner
