Re: Farmall 300 fast hitch arms update
Posted by D Slater on September 19, 2012 at 19:00:58 from (184.15.50.155):
In Reply to: Re: Farmall 300 fast hitch arms update posted by Zachary Hoyt on September 19, 2012 at 17:58:01:
Zach other than the choke cable retaining bracket that Truckerlarry posted about you are probably also missing the cable wire holder that goes in the choke lever hole.
Have both carb end fastening parts if you need or want them and probably have a good used choke cable. Would have to look on that.
