Re: Super C Camshaft Gear and Distributor Drive Gear
Posted by El Toro on September 20, 2012 at 03:39:40 from (108.3.143.30):
In Reply to: Re: Super C Camshaft Gear and Distributor Drive Gear posted by Smith1000 on September 19, 2012 at 17:58:31:
Use a split bearing separator behind the damper pulley and pull from it. This is so you don't break the damper pulley. Hal
