Re: hydrostatic fluid
Posted by mkirsch on September 20, 2012 at 05:30:17 from (64.80.110.74):
In Reply to: hydrostatic fluid posted by realolman on September 20, 2012 at 03:25:25:
Any Agco dealer out there will have the "correct" replacement fluid.
Allis Chalmers lawn equipment became Simplicity, right? In that case, Simplicity dealers should also be able to help you with the "correct" fluid.
Tractor Supply sells a hydraulic fluid that lists about 50 different brands and types that it's compatible with as well.
