Posted by rustyfarmall on September 20, 2012 at 05:56:04 from (67.55.162.174):
In Reply to: Bead blasting carb? posted by IAtractorKid on September 19, 2012 at 18:06:57:
Go for it. Bead blasting is the only way to remove the rust and other deposits down in the bottom of the bowl. I will caution you to either remove the idle metering jet, or cover it so the sand can't get in it because it is the only part of the entire carb that is small enough for the sand to become hopelessly lodged in.
Be sure to completely blow it all out with compressed air, and then be very generous with aerosol carb cleaner into ALL of the passages, then use compressed air again.
The carb cleaner that you soak a carb in just ain't even close to what it used to be, and it won't get the job done.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
