Re: hydraulic hose getting real hot
Posted by pete 23 on September 20, 2012 at 10:55:32 from (74.32.238.2):
In Reply to: hydraulic hose getting real hot posted by pat crawford on September 20, 2012 at 09:37:11:
Getting hot because system is staying on demand. This can happen for various reason. Number one, make sure single to double setting on valves does not have broken or bent roll pin stop. If it has teledepth hitch, may be at end of travel, lingage bent or busted, out of adjustment or bad valve. Orfice screen in regulator valve may be plugged. At any rate, it will ruin a pump if run that way along with a jillion o-rings through out the system.
