Re: Super C Camshaft Gear and Distributor Drive Gear
Posted by Elton Fancher on September 20, 2012 at 17:01:55 from (64.130.156.234):
In Reply to: Super C Camshaft Gear and Distributor Drive Gear posted by Smith1000 on September 18, 2012 at 18:15:04:
I just installed a cam gear in a super c this spring. What I found was that I could not get the gear back on the cam still in the tractor. If you try to force it on you will push the expansion plug behind the cam out of the engine block. Save yourself some trouble and remove the cam, press the gear off. Freeze the cam and press new gear back on.
