Ya, you could build an Elwood transfer case. That"s alot of work and it will only be worth scrap when done even if it works flawlessly.
Here are some pictures to get you started. It would be alot easier to attach right angle drives off both pinion shafts and run two drive shafts forward to a double differential steering Dana. I think I calculated 11.2 x 24 front rubber with the lowest ratio Dana 60. You will also have to install a locker on the IH differential. The B-450 had them. OTOH, maybe not so easy.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
