Re: F 12 wont start ideas please
Posted by John M on September 21, 2012 at 03:59:04 from (67.231.172.230):
In Reply to: F 12 wont start ideas please posted by stumpman on September 20, 2012 at 15:33:32:
Your not getting fuel. The butterfly ear thing is your carb drain. You did turn the fuel back on before starting didnt you. If so take off the line from the pump, crank and make sure its pumping, then work you way to the carb, taking lines loose until you find where its not getting fuel. I suspect one of the discs in the pump is stuck.
