Re: Corn Picker Hubs?
Posted by Angle Iron on September 21, 2012 at 05:49:47 from (69.1.17.68):
In Reply to: Corn Picker Hubs? posted by IaGary on September 21, 2012 at 05:32:55:
That type of hub was used on the #24 picker. It had a steerable middle snoot that clipped on those hubs. I don't recall exactly how the chains hooked up but there were chains and springs to lift the snoot. Cowman you if I recall have a narrow front on one of your project H's that has picker hubs. They are a modified dust cover for the wheel bearings. You had to remove the castelated nut and replace it with a speacial split extension that tightened the wheel beading preload and had a cross bolt to lock it in place instead of a cotter pin. Then a matching dust cover with grease seal went over it using the original bolt holes. The hub extension with the groove stuck out far enough to connect the snoot..
Angle iron
This post was edited by Angle Iron at 05:52:00 09/21/12.
