Float height is 1 5/16". Measured from the carburetor mating surface (without a gasket) to the highest point on the float while holding the throttle body upside down, with the float resting on the needle valve.
If the new needle is shorter than the old one, either they gave you the wrong needle, or the old needle you took out was the wrong one.
If the float height is correct, the fuel level will also be correct.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
