Re: Rear tire valve core
Posted by old on September 21, 2012 at 09:51:45 from (209.86.226.56):
In Reply to: Re: Rear tire valve core posted by 2farmron on September 21, 2012 at 09:29:50:
The valve assembly on the rear tractor tires are a 3 part thing. You have the core which is the valve that opens when you put air in. Then you have the stem which screws into the tube and of course the tube is the most expensive part of the 3 part assembly. Yes you can remove the stem part with out removing the core first
