Re: C OIL LEAK
Posted by Rick Remmert on September 21, 2012 at 18:47:56 from (68.103.4.114):
In Reply to: C OIL LEAK posted by DWCYour Handle on September 21, 2012 at 08:49:00:
It looks like it is doing the samething mine was doing. The seals on both ends of the brake pedal shaft that runs thru the tranny case were leaking. You will have to drain a couple of gallons of the oil out of the tranny. Unhook the clutch and brake rods. The pedals will pull right off. Take the woodruff keys out and slide the shaft out. The case has one in each side. I got replacement ones at NAPA. Just a thought.
