Re: F 12 fuel pump rebuild question
Posted by Tom Fleming on September 22, 2012 at 02:48:26 from (173.233.9.252):
In Reply to: F 12 fuel pump rebuild question posted by stumpman on September 21, 2012 at 19:21:07:
Dennis, the fuel pump is not terribly difficult to rebuild. There are 2 different diaphram configurations in these, and depending upon which one you have will deternine the rebuild kit you get. One diaphram is held on with a threaded piece, another one has what amounts to a pressed "rivot". In either case, you need to disassemble before you buy your rebuild kit. Both can be repaired/rebuilt, but the one with the threaded assembly is MUCH easier to deal with.
Also, rebuild kits are available, but get ready for sticker shock......although they are less expensive (significantly) that buying the whole, rebuilt assembly. Rice Equipment is Pa has the kits. Here is another excellent source, and they rebuild them for you as well:
http://www.classicpreservation.com/fuelpumpkits.html
Take it off and disassemble to determine which style you have. Unless you are really ham-handed, you are not going to ruin anything. Also, you will need to remove it from the engine.
This post was edited by Tom Fleming at 02:49:25 09/22/12.
