A flashing light indicates that the charging system is not operating correctly. Without being there here are two suggestions. (newish alternators can fail, especially "rebuilt" ones). First when it is running at 1/2 throttle, check the voltage across the battery posts. it should be 14.2 to 14.8 volts. If not, and it is about 12.4 or so the system is not charging at all. I would take the regulator and alternator to a auto parts store that will check them. If you are determined to repair/analyze it yourself, you will need the repair manual, or Delco diagnostic procedure from the internet. Jim
