Dennis, one other thing that can go bad on these is the push rod that actuates the pump. These wear over time (as does the cam) and if there is not enough movement to "work" the pump, that will need attention as well. I don't have the exact amount of travel you should have on the pump rod, but I'll try to look it up.
I am sure someone here has either the correct new rod length, or how much travel it should have. As the rod wears, what you will see is a decrease in the GPM output of the pump. this becomes a problem when the flow falls below the consumtion of the engine. Since these have a by-pass built in, it would take alot of wear to get to that point, but it is something else you can check.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
