Re: Mounting a 30 or 31 loader on a 300 Farmall
Posted by rustyfarmall on September 22, 2012 at 09:39:16 from (67.55.162.174):
In Reply to: Mounting a 30 or 31 loader on a 300 Farmall posted by Zachary Hoyt on September 21, 2012 at 18:49:46:
My dad had a #31 on a Farmall 350. He got the spacer blocks from the dealer. The loader had been on an H, and went back on the H when the 350 was traded off.
If you've got some iron laying around, and are handy with a welder, there is no reason you can't fabricate something that will work.
