Re: Building a Wiring Harness
Posted by Harold H on September 22, 2012 at 12:18:04 from (12.23.230.67):
In Reply to: Building a Wiring Harness posted by F4RM@11 on September 19, 2012 at 17:10:26:
If you build your own it will be with modern plastic covered wire. If you want it original, several of the suppliers use the correct cloth covered wires with the proper colored cloth and tracers in the wire, which look just like the original. I have done both and the cloth type originals look the best to me. Both ways will work. Your choice.
Harold H
