Re: B Farmall front trans seal
Posted by gene bender on September 22, 2012 at 13:14:53 from (67.55.226.162):
In Reply to: B Farmall front trans seal posted by Morris Krodle on September 22, 2012 at 11:36:11:
You can break it at the tranny. After you move it a few inches so you can then unbolt the joint you then need to just go dsideways a little with either end of the tractor. I replace the bearing also when doing the seal. Most times it ends up making the tranny quieter. Ive done several. Those bolts holding the u-joint are tapered. Its never been a problem getting the drive shaft back into the pressureplate when going back together. You will need either end of the tractor on some kind of rollers.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
