Re: 66 series question
Posted by pete 23 on September 22, 2012 at 14:18:40 from (74.32.238.2):
In Reply to: 66 series question posted by DJL on September 21, 2012 at 20:59:46:
I will add to the blinking part of your question. It may or may not have a flashing bulb. It all depends on who put a bulb in it. You can easily tell if it is a flashing bulb by just turning the key on without starting the engine. If it flashes then you know it will also flash when you push in the clutch. If it burns steady when not running but flashes when running with clutch in you have some slight leakage into lube system. Far as irregular, those little flashing elements in those bulbs are not real sturdy so it if probably just a poor bulb. I always use steady burning bulbs for replacement as too many times the flasher is not dependable. You would need to put a gauge in where sender goes to get a good reading if you feel it is a problem.
