Re: IH 424 Electrical Problem
Posted by Owen Aaland on September 22, 2012 at 14:18:08 from (216.47.35.54):
In Reply to: IH 424 Electrical Problem posted by Chip Fontaine on September 22, 2012 at 08:31:40:
The light flashes because it has a flashing bulb. It is connected between the key switch and the Gen terminal of the regulator. If the generator is working the voltage from the A terminal of the generator arrives at the Gen terminal of the regulator and will close the contact in the regulator between the Gen terminal and the Bat terminal. When that happens you will have battery/charging voltage on both sides of the bulb and the light will go out. Trouble shooting the generator and regulator should locate your problem.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=665110
