Re: 300 Farmall float adjustment, long post
Posted by CNKS on September 22, 2012 at 17:48:48 from (216.144.104.128):
In Reply to: Re: 300 Farmall float adjustment, long post posted by rustyfarmall on September 22, 2012 at 15:22:50:
Rebuilding has nothing to do with adjusting. The directions in the Operators manuals differ between the H/Super H, and M/Super M. It is in the manuals in black and white. Perhaps you don't have the Super manuals, I see no other reason for you to disagree. If you use the 3 turns out for the initial setting the H and M will probably run ok, but the guy getting your carbs should adjust with the in until rough out until smooth to assure a lean mixture. The Super H/M-up will not run properly if adjusted that way, at least not with any load. I have a 460 that I tried with 4 turns out, it lost power so I use 5 turns. It runs a little rich possibly due to some other problem, but more likely because it doesn't get run enough.
