Re: input: what rear end interchange with 460 r.crop
Posted by D Slater on September 22, 2012 at 19:03:37 from (184.15.50.155):
In Reply to: input: what rear end interchange with 460 r.crop posted by piston on September 21, 2012 at 14:12:12:
Just noticed after the other post you may be using in a puller. 460 improved rears and 504 rears would probably be best although some weight could be saved with a 340 rear. Between 300, 350, 460, 340 and 504 farmall and utility tractors there's all kinds of gear ratios you can get. Probably not worried about hydraulics on the puller also.
